OFAB 195 MSD set up + full conversion option
As title
Option 1
Brand new MSD chip for beiges/ T3 cost (£250 )- £175
Brand new 3 bar map sensor (£80) £50
Set of beiges £80
Adjustable Fuel pressure regulator £50
Complete set up delivered £300
Option 2 efi conversion
new custom braided loom to move ecu into car inc ofab ECU
2bar map sensor
speed sensor
coil pack leads
crank sensor
inlet complete with rail
edis module
fuel pressure regulator
injectors
pedal and cable
Complete package £650 delivered
Option 3
ofab ecu
2bar map sensor
speed sensor
coil pack leads
crank sensor
edis module
loom - tatty not guarenteed so free
injectors
pedal and cable
Complete package £280 delivered
Steve 07725238098
Option 1
Set of beiges £80
2bar map sensor
speed sensor
coil pack leads
crank sensor
edis module
injectors
pedal and cable
Option 3
ofab ecu
2bar map sensor
speed sensor
coil pack leads
crank sensor
edis module
injectors
pedal and cable
Steve 07725238098
adam151082
Aug 30, 2015 08:34 AM
