Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
mk4 front wheelbearing
Old Aug 19, 2012 | 07:58 PM
gjh's Avatar
gjh
Default mk4 front wheelbearing
Anyone on here changed them? Is it an easy job or a pain in the backside? Any specialist tools required (have the usual sockets, spanners basic tool kit stuff)
Cheers folks!
Old Sep 24, 2012 | 12:13 AM
Black Foci's Avatar
Black Foci
I know this post was a while back, but if youve not gotten around to doing it yet, ive done them before. Its easy to take the hub flange out the hub, but the inner bearing splits in half. You can cut them off with a grinder, just be careful you dont cut into the shaft. The most difficult and time consuming part is getting the outer part of the bearing out the hub, it took me quite a while to grind away at it with a dremmel. Theres also a spring clip on the inside of the bearing that you can remove with long nose pliers. When knocking the new bearing into the hub (assuming you dont have access to a press), make sure you only tap the outer bearing and not the inner or youll damage it
Old Sep 25, 2012 | 04:16 PM
gjh's Avatar
gjh
Yes thanls I've done it. Fucked the hub in the process, new hub and fitted now though.
C2 MAK
Aug 20, 2015 09:46 PM
A.t.p
Aug 15, 2015 11:37 AM
track.focus'd
Aug 12, 2015 05:53 PM
3i Jim
Was It You?
Aug 1, 2015 06:33 PM
