Big valve ZT head! £350 Brembo 4 pots *price drop £160*
Engine Machinist
Hi all,
I have for sale a ported+polished silver top zetec turbo head, should be good for big power. spec includes:
3 angle seats
De-shrouded seats
Stainless 214n exhaust valves +3mm larger than standard
Stainless 214n inlet valves +1mm larger than standard.
Ports and throats have been enlarged significantly (taking care around the exhaust ports, as these are a known issue).
Head has been hot pressure tested at 60psi and has also been refaced.
All work carried out by the same place that did speckys tigra heads up until last year
It will be supplied as a bare head with caps and valves only, as you'll obviously want to put uprated springs on it
Only slight issues with it are that it has one visible crack around a spark plug thread, which doesn't affect it at all really except for looks and it also has a small amount of corrosion around one waterway on the head face.
looking for £350 for it
I also have a pair of working brembo 4 pots from a puegeot 406 coupe for sale, they'll take the 300mm peugeot discs, or focus RS discs. they'll need brackets making obviously, but are still a cheap upgrade for most people.
Priced at £160 for quick sale
3 angle seats
De-shrouded seats
Aug 28, 2015 05:30 AM
