Forced air induction kit
Old Aug 16, 2012 | 07:56 PM
ThePoons's Avatar
ThePoons
St170
Default Forced air induction kit
Has anyone fitted one? If so where have you run the induction pipe to the front of the car? I can't see no room/routes?
Cheers.
Old Aug 17, 2012 | 03:57 PM
pani_k's Avatar
pani_k
PassionFORD Member
Easiest route is to follow the standard air routing down by the side of the coil pack and themostat. There isn't enough room to go down the other side of the battery unless you take the cover off and butcher the battery tray.
Old Aug 18, 2012 | 06:44 AM
ThePoons's Avatar
ThePoons
St170
Yeah that Does look like the only route it's just the start of the intake the big round hole you ideally want that sitting out the front off the car instead of behind the half inch cap in the bonnet. Might have to remove a fog lamp and put some mesh there to stop large items getting through
Old Aug 18, 2012 | 11:32 AM
pani_k's Avatar
pani_k
PassionFORD Member
You can route down to the lower grille easily enough.
Nov 1, 2015 06:53 PM
