scort Van problem
Old Aug 12, 2012 | 02:42 PM
dannysconnect's Avatar
dannysconnect
Default scort Van problem
Hi Guys
Just changed a clutch on a MK5 94 reg Escort van yesterday and it wont start
I have connected the battery and all of the electrical connections that were removed when taking gearbox off
I did origionally wire up the starter motor incorrectly and it sparked and started burning. But the engine doesnt even tick over - it is almost as if the battery negative is disconnected, but it isn't
I also noticed on the starter motor there is a small wire running from the battery that connected to the starter solenoid, the circle end of it has come off but there is still metal on it that contacts the starter solenoid. could this be the problem?
Any help appreciated - No clue what I've done & I've never had this problem in the past I've changed dozens of clutches
Ta
Old Aug 12, 2012 | 03:08 PM
RichieST's Avatar
RichieST
Have you checked all fuses, even the big ones in the engine bay fuse box?
Old Aug 12, 2012 | 03:29 PM
7sean7m7's Avatar
7sean7m7
Poor earth connection on one of the straps?
Old Aug 12, 2012 | 03:44 PM
dannysconnect
theres a 50amp fuse in front of the battery that looks a little worse than the others.
There is a small wire on the starter coming from the battery that has broken - but there is still a bit of metal on it left that touches the starter solenoid- do you know where the fuse/relay is located for the starter?
Old Aug 12, 2012 | 03:47 PM
dannysconnect
the wire isnt broken - the connection on the end of it is broken
Old Aug 12, 2012 | 04:12 PM
saph4be's Avatar
saph4be
Repair that wire sounds like your problem
Old Aug 12, 2012 | 04:16 PM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
Ive done this before. Forgot to tighten up one of the bellhousing bolts with the earth strap on it. Same issue.
Old Aug 12, 2012 | 04:40 PM
dannysconnect
do they sell repair wires or will I have to do do this myself
Old Aug 12, 2012 | 04:43 PM
DixieTheKid
Pick-up P100 Power!
Just put a new terminal on the end?
dannysconnect
i did spill some coollant on the starter wires by accident mate - might that be another reason?
Old Aug 12, 2012 | 04:51 PM
DixieTheKid
Pick-up P100 Power!
Is the engine turning over? You have dash lights etc yes?
Old Aug 12, 2012 | 05:03 PM
dannysconnect
No the engine isn't turning over - unfortunately the owner removed the dashboard yesterday so cant check for any lights. I dont think they unplugged the ignition switch thought so I dont think removing the dash has affected it? or could it
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Flatlinedan
Sep 18, 2015 12:41 PM
benw456
Sep 16, 2015 05:27 PM
S3an
13
Sep 13, 2015 10:01 AM
Bighandsuk
Sep 2, 2015 05:23 PM
