Cosworth hybrid turbo reduced to £400
This is my bro in laws and he doesn't use any of the car forums so I'm advertising for him
Turbo specs are
small escort cossy hybrid turbo bigger comp wheel 360 bearing,run at 26 psi
power be around 330-340 but lot more ft/lb .its on a t3 flange
Comp size is 46.4mm and 60mm
Turbine is 53mm 47 mm
Rebuild and balance etc done by Wilksy in Essex, a few of you may know him as he rebuilds and supplies a lot of turbos down are way
Offers around £450
I will pass on contact number for my bro in law if anyone is interested
Thanks
Marc
Turbo specs are
Offers around £450
Thanks
Marc
it does not have a marham shaft so als is your risk but i ran mild als on a gt turbo with no marham shaft for a while with no issues but again at your own risk,
Not sure what boost it is good for to be honest but being cossie i suppose 1.5 - 2 bar is the norm
Dont mean to piss on your thread, but that compressor wheel you state sounds like a standard 60 trim T3 wheel, which wont flow anything like 400hp.
300-320hp would be more like a sensible figure for that compressor wheel.
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
