TDCi Injectors or something else.......basically Help!! LOL
Old Aug 10, 2012 | 03:58 PM
Andy Stoodley's Avatar
Andy Stoodley
Default TDCi Injectors or something else.......basically Help!! LOL
Heres a strange one i could do with some help on please: I have a 2002 Mondeo TDCi 115 Ghia X.....been running okay and used daily, then last December the injectors played up. Had them changed, again all good. Now this week again they played up....took back to the garage that repaired them (shower of s*** they were!) who told me that the seals had gone - which apparently were not replaced originally as they dont have to be! They change them, car runs better...BUT management light still on, and lack of power still. NOT a lack of power as in 'safe mode' but lack of power as in it feels like turbo isnt kicking in (can you tell i am not a mechanic! ) Anyway, this cruddy garage are at a loss - even suggesting it was contaminated fuel (which didnt go down well with Tesco) And now they suggest having it in and stripping it down at my cost.
Any ideas or help or advice would be helpful please
As i am considering trading the car in (even thou i love it) i just want to get it running right and the management light off.
Old Aug 10, 2012 | 04:15 PM
oldford's Avatar
oldford
If the management light is on, one should be able to read a fault code.
Which code(s) are present at the moment? (Preferably complete with number.)
Old Aug 10, 2012 | 04:28 PM
Andy Stoodley
Hi Oldford, thanks for your reply.
The AA came up with 2 fault codes originally - P1631 (main relay power hold) and P2338 (cylinder 3 knock)
I had a diagnostic done by a secondary garage before i went back to the originally garage, and this provided also P1631 and P2338, however also suggested P0100 (mass air flow sensor) P0203 (injector circuit malfuntion cylinder 3) P0204 (injector circuit malfunction cylinder 4) and P0202 (injector circuit malfunction cylinder 2) !!
However when i returned to the original garage who supplied the injectors, they told me it was reading the fault codes because the seals were broken and therefore the sensors were not reading correctly
Old Aug 10, 2012 | 04:34 PM
james kiely's Avatar
james kiely
usually a loss of power like that is the airflow meter andy,again im no mechanic .as far as i remember if you plug it out and their is still no change in the way it drives it is the airflow meter thats at fault .
worth a go
Old Aug 10, 2012 | 04:54 PM
Andy Stoodley
Thank you James, i will try this......is i can follow the instructions on youtube as too getting to it! LOL
Old Aug 10, 2012 | 05:02 PM
oldford's Avatar
oldford
Ehhh? Which sensors were not working correctly?
Remember that the fault codes (p0202, P0203 and P0204) on the injectors have to do with the electrical connection.
The codes have nothing to do whether or not the injector is even injecting fuel or leaking or whatever. At least 3 injectors are having electrical problems, probably an open circuit.
The P2338 is usually incorrect coding of the injector or it needs a new one.
I think you need to consult another garage/dealer. Over here we have specialist diesel centers, like Bosch. Don't know if you have them?
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
The Enigma
Sep 29, 2015 10:31 AM
Sp3no
Sep 27, 2015 07:23 PM
