What power should this spec make guys
Aug 9, 2012 | 12:59 PM
It's a 3 door cosworth the spec that I know is
stage 3 msd chip L6
3 bar map
T34.63
Dark greens
500 cooler
Group A filter
044 pump rewired as well
Freshly built engine
Ported head
4" rolled out scorpion
I think that's it lol
Aug 9, 2012 | 01:03 PM
Should do an easy 350/350 and with the map tweaked after you could max the greens out and get maybe 370 hp..
That engine to me is crying out for some 55lb siemens and a bd 14 inlet cam !!
Would do 400/400 then..
cheers danny
Aug 9, 2012 | 01:06 PM
Would this be reliable power or likely to break a lot lol
Cool how much is a cam and 55s
I guess I will need a new chip as well
Aug 9, 2012 | 01:09 PM
Keep the current setup, the 205 block will only take so much so I would not push it. Its good and reliable what you have now I think..
Aug 9, 2012 | 01:10 PM
Quote:
Originally Posted by
cossie891
All depends how good the lump is but you say its fresh so the car well set up and it should last well mate..
Sell the greens and chip and get new chip and black 55s..
If you dont have valve pockets then you cant go bd14 but can go ab07 with out valve pockets..
So chip and blacks from stu cam from newmans as he is cheaper than anyone listing ab 07 and well set up and it will be a little flying machine!!!
cheers danny
Aug 9, 2012 | 01:11 PM
nixon_2wd
205 block is fine with 400 hp all day long its after that power i reccomend a long stud 200 block..
cheers danny
Aug 9, 2012 | 01:14 PM
Cool the pistons have been pocketed and they are a .5 the engine is that fresh its still at the builders lol
Aug 9, 2012 | 01:15 PM
Oh yeah the head has been ported for 500bhp it's all been rebuilt new stem seals valve guides etc
Aug 9, 2012 | 02:07 PM
750hp escos
cheers danny
I dont believe so, however a longer duration camshaft will reduce the dynamic comp ratio hence lowering cylpressures. People tend not to change cams on these setups and so the high dCR combined with high boost cracks the 205s.
Aug 9, 2012 | 04:38 PM
So how far can a 205 be pushed then, 370?
Aug 9, 2012 | 07:15 PM
mines been on 420 bhp for years and never had a problem with it(well not the
block anyhow)
Aug 9, 2012 | 08:02 PM
Cool
Aug 9, 2012 | 08:51 PM
nixon_2wd
My 205 block was well into the 500s
Its spun a shell now but the block is sound
Steve
Aug 10, 2012 | 11:24 AM
cossie891
Mate.... 350 Is "NOT" Slow and will be reliable
Aug 10, 2012 | 11:38 AM
I know it ain't slow lol it is naughty
Aug 10, 2012 | 01:48 PM
plenty of 205 block well into the 400's so no worries there
Aug 10, 2012 | 04:39 PM
I'm at 400bhp on a 205 and it's mega fine.
Dahl88
Aug 22, 2015 08:16 PM
c20tbo
Aug 17, 2015 10:19 PM
track.focus'd
Aug 12, 2015 05:53 PM
