Clutch Ratchets about to go pop :(
Old Aug 2, 2012 | 04:20 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
Default Clutch Ratchets about to go pop :(
As above a week before fordfair (on my FRST), whats the best way to modify/improve/replace it peeps?
the heat really is on!
Old Aug 2, 2012 | 04:21 PM
cossie891's Avatar
cossie891
Not yours as well lol
Mines shit and so is the kiddy in the mk 4 escorts his pops all the time lol
Old Aug 2, 2012 | 04:28 PM
Adam.'s Avatar
Adam.
LOL bloody things!, what engines in that Escort mate?
Old Aug 2, 2012 | 04:31 PM
cossie891's Avatar
cossie891
2wd cossie mate
Old Aug 2, 2012 | 04:33 PM
adriankt77's Avatar
adriankt77
mk5-6 escort peddle works mint mate . i done this mod on my frst
Old Aug 2, 2012 | 04:34 PM
cossie891's Avatar
cossie891
How do you do the mod mate
Old Aug 2, 2012 | 04:35 PM
adriankt77's Avatar
adriankt77
it uses the allen bolt for the adjuster and works perfect
Old Aug 2, 2012 | 04:36 PM
cossie891's Avatar
cossie891
How do you change it all
Old Aug 2, 2012 | 04:46 PM
adriankt77's Avatar
adriankt77
tbh mate it was 2yrs ago i had done this but from what i can remember i used the escort peddle with allen bolt adjuster it uses a black ratchet part thats fitted in the peddle. i think i welded a nut on the end of the bolt and it was the nut that pushed on the ratchet part and pulled the cable?
BUT after doing that work to get that peddle to fit and work i took it out a few months later and modified the mk3 peddle cos i didnt like the shape of the escort peddle. ( it has a slight kick to the left ) which took it to close to the heater matrix if i remember rite. if u have a welder and are a little handy with moding things its a simple job mate.
Old Aug 2, 2012 | 05:39 PM
RSargie's Avatar
RSargie
Is there not a kit / guide etc from burton?
Old Aug 2, 2012 | 05:44 PM
GUZZLER's Avatar
GUZZLER
The escort pedal is not a direct fit in to the fiesta
Old Aug 2, 2012 | 05:56 PM
adriankt77's Avatar
adriankt77
cant remember 100% but wasnt far off and didnt take long to fit . was better of moding the mk3 peddle to start with tbh but a little more work was involved with welding, cutting etc
hows things mr wright ?
Old Aug 3, 2012 | 07:41 AM
Adam.'s Avatar
Adam.
I need to sort it as its making my clutch drag now :-(
Old Aug 3, 2012 | 07:48 AM
STeve's Avatar
Super Moderator
I suggest doing it asap Adam as you dont want it giving up next week
Old Aug 3, 2012 | 09:28 AM
Adam.'s Avatar
Adam.
Have just ordered a revised peddle+ parts where you bin off the plastic ratchet totally, read up about it on FT.com
Old Aug 3, 2012 | 11:26 AM
zippyobrien's Avatar
zippyobrien
You can get ally clutch quadrants other wise.
For the ultimate solution you want a mk5 zetec s pedle box and go hydro clutch. Sooooo much better.
Old Aug 3, 2012 | 12:36 PM
STeve's Avatar
Super Moderator
sound move that
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
