expolded diagram or pictures needed
i cant figure out how the pins and springs are suposed to fit the cat and manifold together on a mk5 escort xr3i 1.8 16v .
ive got new bolts , new springs , new locking pins with securing clips and a new manifold to cat wire gasket .
ive got the bolts in the manifold and the pins and securing clips holding them in , i cant figure out were the springs go and how you tighten it up
it may sound the stupidest question in the world , ive put the engine in a ka and the engine did not come with a manifold or cat , ive purchased a standard manifold and cat , basically if i do it one way it wont tighten up properly and just hangs loose and if i do it the other way i cant get the nuts ot the bolts because the cat wont push on to the manifold enough with the gasket in place .
so yea if any one has got a picture of how it goes together or even an exploded diagram that would be great
cheers
cheers
yea i tryed that but the pictures and description in the haynes manual ae vague to say the least , ive searched google with no success so im hoping you guys can help me out
has anyone got one of the following :- fiesta rs1800 , fiesta xr2i 1.8 16v , escort xr3i 1.8 16v
if so could some one please tell me the correct assembly procedure for the bolts , springs , pins and retaining clips that hold the manifold to the cat pipe
ive looked every were including the haynes manual and no decent description or pictures are available
cheers
cheers
steerfromdarear
28
Jan 29, 2016 06:14 PM
155lee
Aug 14, 2015 11:21 AM
