yb mains caps
A blocks main caps are for that one and only individual block and can not be changed between blocks at all..
If you have a decent block and an odd set of main caps then you can get the block re line bored but its not cheap at about Ł250
cheers danny
cheers danny
IIRC, the block is cast, the caps are made and bolted down, then the hole for the crank is machined all the way through, that way the holes are perfectly in line and any casting probs for caps are sorted.
Normal size. Usually you can just get away with machining a little metal from the caps and line honing back to standard size, not every time, but 90% of caps go on without too many dramas.
wowk
Mar 30, 2021 07:49 PM
