Removing water pump
Old Jul 30, 2012 | 09:49 PM
Jasoncmor's Avatar
Jasoncmor
Default Removing water pump
Hi all.
I am currently changing my cambelt and water pump on my car, and need a little advice on how to remove the water pump?
Car is a mk4 1.25 fiesta.
Cheers, Jason
Old Jul 30, 2012 | 09:55 PM
studabear's Avatar
studabear
For the water pump undo around 6 10mm headed bolts
It isn't driven by the cam belt, can be squeezed past it to.
When doing the cambelt the crank shaft isn't keyed for the cambelt pulley, you really need the timing tools.
Old Jul 30, 2012 | 09:58 PM
Jasoncmor's Avatar
Jasoncmor
I know that about the crank and pulley, I have locking tools already to do the job.
Cheers.
Old Jul 30, 2012 | 10:21 PM
langer's Avatar
langer
If you don't know how to take the water pump off you shouldn't really be doing the timing belt.
Old Jul 31, 2012 | 10:57 AM
Jasoncmor's Avatar
Jasoncmor
Thing was I didn't see the bolts, obviously didn't look close enough, didn't know how many there were and didnt realise i'd need to remove the pulley off the pump to see most of them.
jonfoc
16
Sep 11, 2018 05:35 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
grishenko45
Sep 9, 2015 12:58 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
hopper350
Sep 4, 2015 12:53 AM
