new to the site
Old Jul 25, 2012 | 05:53 AM
RS BINE's Avatar
RS BINE
Default new to the site
hi folks, im new to the site and wandered if anyone could help. Ive recently bought a s2 rs turbo with efi conversion it is a wee bit tappy on idle although ive heard worse but its quite noisy at high revs. it has an uprated cam but unsure of the make and the previous owner said he changed the tappets but just wandering if it possable to put the wrong ones in for the cam it had. i just had it set up and got 164bhp at 9 psi so its producing power but i dont like to rev it as i dont like the noise at high revs. any help wud be appreciated.
Old Jul 25, 2012 | 06:05 AM
STeve's Avatar
Super Moderator
very common on these engines, some of the causes are poor breathing bad oil circ, needs a oil change or teppets are simply goosed as most are made out of chocolate like the cams, 9 times out of 10 drop in some new lifters with a oil change and its sorted
Old Jul 25, 2012 | 07:09 AM
RS BINE's Avatar
RS BINE
changed the oil and filter last week and the guy i bought it from said the tappets were just done
Old Jul 25, 2012 | 07:17 AM
S1's Avatar
S1
What oil & what grade did you put in it?
Old Jul 25, 2012 | 07:40 AM
RS BINE's Avatar
RS BINE
fuchs titan pro race 5/40 it was bit louder before i changed the oil
Old Jul 25, 2012 | 07:42 AM
RS BINE's Avatar
RS BINE
do you not need different tappets if cam is uprated or am i speakin s**t?
Old Jul 25, 2012 | 07:54 AM
STeve's Avatar
Super Moderator
not really only if the tappets are changed from hydraulic to adjustable, as for tappets being just done it means nothing as for one your trusting the sellers word, I bought a fiesta turbo just after christmas and seller told me it had a recent complete top end rebuild and mine sounded like a bag of spanners on tickover, bought new lifters from matt lewis for £45 its now as quiet as a mouse, check all the breathers etc too as they are known to block up which does not help, also check lobes on cam when changing tappets
Old Jul 25, 2012 | 08:27 AM
RS BINE's Avatar
RS BINE
ok cheers new tappets it is then, want to change rocker gasket anyway as its weeping a bit before i go for beige injectors and chip.
Old Jul 26, 2012 | 12:44 PM
paul-h's Avatar
paul-h
It's always good practice to change both cam and lifters as your cam will eat your new lifters in no time. The cam will be work hardened by now and will eat the followers! May aswel check the cam for wear whilst you are in there!
Old Jul 26, 2012 | 02:21 PM
RS BINE's Avatar
RS BINE
going to get the cam checked while in there but its an uprated cam thats in it and trying to watch the pennies at the moment although if it has to be replaced then it will be.
Marv888
Sep 26, 2015 03:44 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
