Breaking 3 Door Sierra Cosworth, 393BHP, Big Spec
Breaking 3 Door Sierra Cosworth, 393BHP, Big Spec.
HPI Clear, covered 107k with full history and old mots, comes with a folder full of receipts, also a folder with all the pictures from when it was stripped to a bare shell and fully restored, all genuine panels, the car is on an E plate,
Engine is 393BHP, L6 ECU, light blue injectors, 3 bar map sensor, T35 Turbo .48 housing, - 31 Actuator, 205 block, T5 gearbox in excellent working order with no whines or crunches, 7.5" rear diff again in excellent working order, up-rated rear diff mount.
17" Compomotive Alloy Wheels fitted with 215-4-17 Tyres, 6 Pot Compbrake Calipers with 330mm discs in very good condition. Koni suspension,
Airtec 40mm turbo cooler, rs500 inter cooler 60mm with 60mm out lets, alloy radiator 50mm, slim line fans,
Group A fuel pump, up-rated engine mounts, oil breather, swirl pot, baileys header tank, samce boost and water hoses, baileys dump valve, baileys power steering bottle, washer bottle.
Lots of Chrome under the bonnet.
The shell will be sold fully trimmed,
All parts available.
are the front indicators available? if so how much?
also how much for the gauge holder where the centre vent should be?
cheers Matthew
cheers Matthew
Thanks Andy
Still love Cosworths lol, I don't think I would have ever sold mine if this hadn't happened :-(
This would be the way forward for me if i'm staying with them though.
Karl
Karl
