2wd sierra cosworth were do you fit the oil pressure gauge to
Old Jul 23, 2012 | 08:38 PM
mulla's Avatar
mulla
Default 2wd sierra cosworth were do you fit the oil pressure gauge to
just got one want to fit it to the engine were abouts is it fitted to ,i know oil pressure gauge but were is it
Old Jul 23, 2012 | 08:55 PM
wayne dowling's Avatar
wayne dowling
It's on the nearside of the engine under the inlet manifold hop that helps
Old Jul 23, 2012 | 09:39 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
There is a small block the turbo oil feed and oil pressure switch go into t into that! My gauge is a vdo one and electric so the sender it comes with dose the gauge and oil light on the dash so i just had to replace the original switch!
Old Jul 23, 2012 | 09:53 PM
wayne dowling
U can get an adapter that fits in so u can run ur pressure gauge and oil pressure switch u can get them off ebay
Old Jul 24, 2012 | 08:24 AM
mulla's Avatar
mulla
yeah already got one was just looking were it goes
Aug 14, 2015 07:29 AM
dal3door
Aug 13, 2015 06:55 AM
adam151082
Aug 11, 2015 04:50 PM
martynhomer01
16
Aug 4, 2015 09:55 PM
