Ford Rs Parts For Sale (Not cosworth, or Cvh Turbo) All Ford rs parts for sale in here that do not fit in the popular Cosworth or Cvh turbo sections. Starting a topic requires you to have purchased a gold membership.
Breaking 1.8 zetec turbo fiesta
Old Jul 17, 2012 | 10:07 PM
James998's Avatar
James998
Default Breaking 1.8 zetec turbo fiesta
1.8 silvertop zetec e, skimmed pistons, decomp plate, twin head gaskets, oil feed and return in block, breather welded onto camcover, blank plug thing for old breather on block, unknown mileage but ran spot on, slight oil leak from camcover gasket. Comes with alternator, power steering pump, flywheel and clutch. Ran 211bhp at 11psi.
Fiesta diesel gearbox from a mk4 courier van so is cable speedo, unknown mileage but drove well, very clean with no leaks.
Fiesta turbo OFAB ECU, comes with wiring loom but its spliced into a mk5 fiesta loom so might be salveagable but unsure.
Escort T3 turbo and manifold, very little play, boosted well and didn't smoke at all.
EFI inlet manifold with throttle body, injectors etc
Fiesta turbo clocks on 70k, can come with connector and small amount of loom if required.
Driveshafts to fit mk4/5 fiesta/puma i imagine will fit more, the long shaft doesn't have a center bearing so is ideal for use with a big zetec conversion.
Coilpack and uprated leads
Adaptor plates to fit EFI inlet and escort turbo manifold to zetec engines
Offers on everything, all located in Lincoln.
Old Aug 5, 2012 | 11:36 AM
dnbmashuo's Avatar
dnbmashuo
Default 1.8 zetec turbo
Hi There. Do you still have the engine for sale? I would be interested in buying the whole package if possible?
Old Aug 14, 2012 | 12:12 AM
mothrs2k's Avatar
mothrs2k
Have you still got coilpack and leads m8?
Old Oct 14, 2012 | 10:47 AM
Smidydevil's Avatar
Smidydevil
interested in engine ,turbo and conversion plates pm me
Old Oct 16, 2012 | 08:14 PM
danielson04's Avatar
danielson04
How much for turbo mate?
Dubs44
Aug 21, 2015 02:42 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
gingerturbo
Aug 11, 2015 09:44 PM
turbobill
Aug 1, 2015 08:55 PM
