Dying S2 :(
It starts from cold find but after around 10 seconds is gets lumpy then totaly dies unless you rev it, ive posted a cpl of times but its been pushed down, perhaps the right people wernt on to answer? Just a quick reply is all i ask Im sick to death of this problem, cheeRS. pete
Its the same problem im getting. But once my car has started it runs lumpy for a few seconds like you have mentioned and then it clears but once it starts to warm up the revs drop below 500 rpm. I think it just needs a good tune good luck
leaky warm up injector, auxillary air device, metering unit, mixture or a combination of all of them. unfortuantly the mfi set up needs lots of TLC to run at its best one small problem and it can cause hell.
have you got a cam in it, im guessing its standard set up
Originally Posted by Turbo Reecey
Dizzy module sounds to me
)Is it likely to be one of the sensors or something like that because ive vertualy changed everything?
