Emissions on a mondeo
Not much to go on:
CO: 0.34% FAIL - possible catalyst deteriorating OR mixture too rich
HC: 409PPM FAIL - HIGH, maybe leaking injector or compression loss?
Or old spark plugs, maybe fouled by the oil usage?
Do you have the other readings from the test? Like CO2, O2 and lambda-number?
What are the readings at idle? (Also include CO2, O2 and lambda-number if available).
Im an MOT tester myself here is some pointers i posted on another site
High HC reading means excessive unburnt fuel could be cause by:
1. Spark plugs need replacing or faulty leads,cap,rotor arm,coil pack check ignition system
2. Faulty CTS ( cold temp sensor )
3 Mechanical fault if present engine will not be running even
4. Lambda sensor
5. Defective air filter
High Lambda reading means the AFR ratio is not correct could be caused by:
1. The engine having a high HC level see above to rectify
2. A leak in the exhaust system even if a minor leak
3. A defective lambda sensor
4. A leak on a vac or intake pipe.
High CO reading can be cause by:
1. All of the above
2. Was the vehicle tested at correct temp was cat allowed to get to operating temp
3. Defective Cat
4. Lambda sensor
1. All of the above
3. Defective Cat
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
The Enigma
Sep 29, 2015 10:31 AM
