Mk 2 Mondeo subframe alignment pins
Old Jul 11, 2012 | 09:38 PM
cossie04's Avatar
cossie04
Default Mk 2 Mondeo subframe alignment pins
Got to remove a mk2 mondeo gearbox and read that i will need alignment pins when re attaching the subframe. Anyone used these before to fit a subframe? What do they look like and where do they go please?
Cheers, Ed.
Old Jul 11, 2012 | 10:05 PM
studabear's Avatar
studabear
holes in the rear of subframe n/s and o/s, they locate in the chassis rails. Got some in my toolbox at work,
Old Jul 11, 2012 | 10:07 PM
studabear's Avatar
studabear
http://www.ebay.co.uk/itm/SUB-FRAME-...item53ec1e3681
Says on here focus's too, I've had subframes off a focus without using them.
You could mark the subframe up with some tippex marks.
Old Jul 11, 2012 | 10:16 PM
Roscopeco's Avatar
Roscopeco
P8 Managed S1 with ALS
Hope the subframe bolts have been out before had a few over the years rip the captive nuts out
If they do you have to take the carpet up and cut back the grill in the bulkhead and put a spanner on them
Old Jul 12, 2012 | 09:27 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
You can get away with removing the pair on the gearbox side and just loosen the other two. That's what I did and the subframe aligned perfectly afterwards.
mark94
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
muz
Sep 30, 2015 08:29 AM
The Enigma
Sep 29, 2015 10:31 AM
