Help pls
Old Jun 26, 2012 | 03:53 PM
Omitsean's Avatar
Omitsean
Default Help pls
Hi need help just had some wheel bearings put in gone back to car to put together half way throw and trying to put the hub I think back on to drive shaft throw new bearing but it's like it gets stuck when the hub goes to the first grove pls help need car for work in morning forgot to say it is a mk3 escort cab with a Rs turbo engine
Old Jun 26, 2012 | 04:45 PM
beaver rs 88's Avatar
beaver rs 88
in the garage
If the driveshaft goes through the new bearing ok then check ur lining the splines up on the hub flange with the driveshaft
Old Jun 26, 2012 | 04:58 PM
Omitsean's Avatar
Omitsean
It does start to go on but when it reaches the first grove it stops are the diameters the same on a escort 1.6 cab mk3 as a rs turbo tho cause I gave the reg Wich is still logged as a 16 cheers for help
Old Jun 26, 2012 | 05:29 PM
paul-h's Avatar
paul-h
You may have answered your own question there mate.
Old Jun 26, 2012 | 05:45 PM
Omitsean's Avatar
Omitsean
But all the ones I seen for sale say they fit them all
martinmilne
Oct 18, 2019 02:18 AM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
cozzy jeff
Aug 14, 2015 05:46 PM
Porkie
21
Dec 16, 2004 10:23 PM
woodz77
Sep 20, 2004 04:45 PM
