Turbo Cabrio suspension springs
Old Jun 25, 2012 | 08:06 PM
studabear's Avatar
studabear
Default Turbo Cabrio suspension springs
I'm wanting to alter my suspension on the cabrio, its a bit too low, I can't get the tracking gauges on it at work.
Its currnetly on a G-max kit which I reckon is lowering it around 60mm, Ideally I'm thinking of a set of 35-40mm springs, keep the shockers if possible and probably poly bush it at the same time. I'm still on 15" wheels with 195/50v15's I wouldn't mind the suspension with a bit more forgiveness.
What springs/supsension are people running?
Stu
Old Jun 25, 2012 | 08:23 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
I've got konis and either -40mm Gmax or -30 Koni springs to fit onto my cabby.
One or the other will be on ebay next week!
Old Jun 25, 2012 | 08:28 PM
studabear's Avatar
studabear
pm on its way dave
Old Jun 25, 2012 | 09:37 PM
mentalasanything's Avatar
mentalasanything
I have Koni adjustable shocks with AVO -35mm springs. Sits a bit high for some but I think it's spot on.
Lee
Old Jun 26, 2012 | 11:24 AM
s6boy1979's Avatar
s6boy1979
Dont forget the cabs are heavier than the tin top so will always sit a bit lower. Also different makes tend to lower by different amounts. I had Gmax shocks and -40mm springs and the car was on the deck but changed them to Koni shocks and -40mm springs and sits nicely now. What size wheels you got?
Old Jun 26, 2012 | 02:27 PM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
Koni's & 30mm apex springs, fully polybushed, sits perfect and ride quality is good
Old Jun 26, 2012 | 03:17 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Spax on mine.
Old Jun 26, 2012 | 06:23 PM
studabear's Avatar
studabear
have you got a side on picture matey?
Old Jun 26, 2012 | 07:47 PM
bigryrs's Avatar
bigryrs
RSHoleinator
Mines needs new suspension and poly bushed but that's a job for winter
Old Jun 27, 2012 | 10:24 AM
Rob_DOHC's Avatar
Rob_DOHC
I used generic springs from rally design, they are listed under springs-ford. You can choose length (std, -1, -2) and spring rates. TBH for the price im really chuffed with them. Think they were 16 squidilys each. I used -1" which looks more like a 40mm drop.
I have some avo rear springs kicking about that I can measure for you if you like? If they are more suitable you can have them.
Rob,
Matt Baxter
Sep 16, 2015 08:30 PM
Chopshop85
Aug 17, 2015 06:38 PM
A.t.p
Aug 15, 2015 11:37 AM
Botts
Aug 13, 2015 04:16 PM
dal3door
Aug 13, 2015 06:55 AM
