Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Any Focus mk1/st170 Suspension Guru's please?
Old Jun 24, 2012 | 01:41 PM
svt-focus's Avatar
svt-focus
Default Any Focus mk1/st170 Suspension Guru's please?
Hi, i am not sure if this is the right forum , i looked through them all and it looks like this is the right place but please move/delete if necessary;
I have koni adjustable rebound front dampers with eibach pro springs just fitted to my st170, and i have standard rear shock absorbers with eibach pro springs.
As we all know the focus rear suspension has the springs seperate on the rear arms and the rear damper is a standalone unit in normal place;
The dilemna is i also have a new spax rsx coilover kit sat behind me but want to get my money worth out of the koni front dampers before fitting the whole coilover system.
Soo, is it ok to fit the spax rsx rear shock absorbers only for the meanwhile, meaning all the spax springs and adjustable spring stuff would not be used either.
Thanks in advance for any advice.
richierich1986
Sep 18, 2015 03:29 PM
truffleshuffle
Sep 10, 2015 09:35 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
