Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
zetec and ST170 suspension
Old Jun 23, 2012 | 06:57 PM
pyrothrax's Avatar
pyrothrax
Default zetec and ST170 suspension
Hi all,
This question may have been asked before but,
Can anyone tell me the difference between the MK1.5 zetec and ST170 suspension, is their a difference in,
Spring rates,
Damper bound and rebound,
Ride height
and does it look visualy different eg. bright yellow like a set from Spax.
I also understand that the ST170 suspension can directly replace the zetec suspension, can anyone confirm that.
Thanks for any help
Tom
Old Jun 23, 2012 | 07:54 PM
minder's Avatar
minder
there is no difference between looks but i know that the ST170 suspension is lower than the standard mk1.5 zetec and a lot stiffer as well
Old Jun 24, 2012 | 08:38 AM
pyrothrax's Avatar
pyrothrax
Thanks for that, now i just need to find a set.
I'm also assuming the roll bar is stiffer, can anyone confirm that too?
Old Jun 24, 2012 | 12:20 PM
pyrothrax's Avatar
pyrothrax
Another question.
Are the dampers different, someone said that the dampers are all the same on all focus trims apart from the RS model.
Old Jun 26, 2012 | 04:41 PM
yunii's Avatar
yunii
the st170 springs lowers car by 25mm to the zetecs, also stiffer & a little harder ride, i have 2.0 esp with st170 springs allround & front suspension legs & all below in signature
yunii
Old Jun 26, 2012 | 07:07 PM
pyrothrax's Avatar
pyrothrax
Thanks Yunii, so is their a big difference in handeling with a full set of new ST170 springs and shocks,
And how noticable is the ride hight drop.
Old Jun 27, 2012 | 10:46 AM
yunii's Avatar
yunii
this an old pic with mp3 alloys with 215/40/17 tyres,non st suspension. one thing is even with st suspension/springs,the rear could do with 35mm drop, ideally eibachs would do perfect. as st springs sit a little high at the back.
with stock 16s
with st170 brakes/springs & suspension
with st170 alloys on 215/45/17s tyres .front
the rear.
side view
the with usa tails:
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
