Possibly looking at RST tomorrow, pointers?
Old Jun 23, 2012 | 05:35 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
Default Possibly looking at RST tomorrow, pointers?
Besides the obvious is there anything in particular i should look for/check?
I've had a mk4 before but not a turbo, and i've got a mk4 project at moment so know most of problem areas rust wise.
Any tips or points? Cheers!
Old Jun 23, 2012 | 05:40 PM
studabear's Avatar
studabear
Check everything possible, is it standard or modded
Old Jun 23, 2012 | 05:53 PM
xtatiana01x's Avatar
xtatiana01x
Check if breathing heavy, good way is if the oil filter cap lifts up or falls off after a good kick in
You want to see it from cold start (not started before you get there)
Check for smoke on start up, on boast and on lift off
Alittle puff of black smoke on gear change is ok but make sure it's not excessive
Flat spots on boast or it popping and banging while on boast
Oil leaks
Tapping, if it is it's not the tappets it's the cam it's self due to bad design.
And make sure everything feels tight and on road test
And if you know about rust areas that's ok but alot of people forget to check around the rear springs on the chassis legs
Good luck mate
Old Jun 23, 2012 | 06:09 PM
AstoN_B's Avatar
AstoN_B
Mods wise: "ebc vented discs and pads. full magnex stainless exhaust. fully adjustable koni suspension." and says its chipped too. will pedley will be checking it over to make sure it's running 100% once i've bought one.
It's advertised over 2.5k so shouldn't be a rotter. Little scab near windscreen and one near rear wiper. 90 spec, has 17" team dynamics on but i'd change them.
Not expecting concours. Hopefully the weather is ok and i can give it a good look over.
Old Jun 23, 2012 | 06:39 PM
studabear's Avatar
studabear
Whereabouts is it for sale?
Old Jun 23, 2012 | 06:56 PM
STeve's Avatar
Super Moderator
make sure you drive it and test everything before handing over a penny
Old Jun 23, 2012 | 08:08 PM
AstoN_B's Avatar
AstoN_B
Bolton. Won't be buying it tomorrow cause I'm waiting for a guy to come buy my trials bike first.
Been in the trade for a few years now so know about buying etc, just wondered if there's anything Rs specific.
Cheers guys.
Old Jun 23, 2012 | 08:24 PM
Robs Frst's Avatar
Robs Frst
I always went with this when buying a Rs Turbo, when buying a S1,S2 and FRST they all checked out good ones by following this guide.
https://passionford.com/forum/ford-e...de-advice.html
Old Jun 23, 2012 | 08:28 PM
AstoN_B's Avatar
AstoN_B
Cheers dude forgot all about that.
Will have a read tomorrow.
Old Jun 23, 2012 | 09:34 PM
gingeRS's Avatar
gingeRS
excellent guide
Old Jun 25, 2012 | 11:41 AM
AstoN_B's Avatar
AstoN_B
What a disappointment.
Fuse box rotten, then smothered in wax oil, similar with battery box, back window was ready to fall out of hatch, carpets were swimming.
The search for a nice, red late turbo continues.
Old Jun 25, 2012 | 12:37 PM
E980VTJ's Avatar
E980VTJ
good luck
Old Jun 25, 2012 | 12:44 PM
luke19790_3's Avatar
luke19790_3
you won't find a rust free S2 for that money.
all the s2's i looked at around that money were rusty/over priced.
Old Jun 25, 2012 | 01:38 PM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
A decent one will cost Ł3500+ imo although you may get lucky and find one in your budget but expect to pay a few quid getting it up to scratch and you are better going for one in good nick in any colour rather than limiting yourself to just a red one m8, but good luck with your search
Old Jun 25, 2012 | 02:54 PM
gingeRS's Avatar
gingeRS
i just picked up a rot free series 2 on an F for less than 2k
they are out there just gotta keep looking
best of luck with the hunt
Old Jun 25, 2012 | 03:15 PM
luke19790_3
i'm sure if you strip the bodykit off and remove the underseal you will find rust. unless someone as restored it
Old Jun 25, 2012 | 06:45 PM
AstoN_B's Avatar
AstoN_B
It was advertised at 3k. Looked and sounded very good when I spoke to the guy.
Just a shame he wasn't totally honest about it.
I'd consider mercury grey or red, last escort I had was white so don't fancy white again, and black is a royal pain in the arse cause I'm into detailing so id want it prect 24/7.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
A.t.p
Oct 23, 2015 07:54 PM
griffo69
Oct 4, 2015 11:58 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
