i dont theres much in the swap for the pins, they just clip out
you need the Map sensor too
i'd do £160 posted on my ofab ecu and Map
i think the map plug may be different but is the same as a washer bottle but not 100% if there is any difference
i would then part out the loom on ebay
i expect its a matter of soldering a new one on buyt have a looksee
i know i used to convert looms from oac to ofab but thats was 10 years ago, i dont remember much about it
