cortina estate mk5 cosworth 24v
Hi, I'm Marco, I'm from near Berlin. I wanted you here to present my ford cortina mk5 cosworth v6 24v project. Here are some data:
- ZF LSD with 70% lock value
- 5 stud vented Disc conversion on the rear axle, Scorpio calipers
- Polybushes
- granada hubs on front
- cosworth 24v bob engine
- mt75 gearbox
- refacing camshafts 260°
- 6x jenvey throttle bodies
- 6x audi s4 single ignition
- adaptronic 420c
- 7 x 17 BRM-Wheels
without springs and unpainted
5 stud conversion on the rear axle
rear brakes
engine fitted
intake manifold
throttle bodies and airhorns
and state is
- Polybushes
- mt75 gearbox
- adaptronic 420c
- 7 x 17 BRM-Wheels
rear brakes
engine fitted
intake manifold
and state is
still a very nice project
get some more pictures of the build as you get it done and we will supply you with free encouragement and may even give you some good advice if you get stuck
Aug 14, 2015 07:29 AM
