Focus st170 code P1381
Old Jun 12, 2012 | 06:06 PM
Comanche's Avatar
Comanche
Default Focus st170 code P1381
Hi - I am trying to help a friend sort out his st170, and we keep getting the code P1381 coming up. The engine runs well and smoothly above about 2000 rpm., but will not idle very well, if at all. On the occasions that it does idle it runs really lumpy and sounds like it has really hot cams in it.
We have checked the cam timing several times, and we are confident that it is spot on. However, clearly there is a problem in that area, and we wonder how we can check if the variable cam timing pulley on the front of the inlet cam is working properly. We think the problem might be there, - or with the solenoid that controls it on the top of the cylinder head.
Really hope someone can help or advise. - Thanks.
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
Tank Mike
Sep 10, 2015 07:56 AM
focus2351
Sep 9, 2015 09:33 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
