rs tubro engine and box all reconed
Old Jun 10, 2012 | 02:10 PM
Topcat's Avatar
Topcat
Default rs tubro engine and box all reconed
SELLING MY RS TURBO ENGINE s1,IT HAS BEEN FULLY RECON D JUST NEEDS BUILDING,,
CRANK REGRIND WITH NEW BIG ENDS
NEW FORGED PISTONS AND RINGS
AND A RE BORE ON THE BLOCK.
THE HEAD HAS NEW VALVES WITH 3 ANGLE SEATS WITH UNLEADED SEATS
NEW CAM AND FOLLOWERS,STEAM SEALS, SPRINGS NEED FITTING NEW HEAD BOLTS ,,THE CAM IS A CVH34K
CAM BELT AND PLUGS ALL THE PARTS WAS FROM BURTON STIL IN THE BOX NEVER OPENED...
FELPRO GASKET SET !! I DO RECAMEND YOU GET THE CRANK AND PISTON LIGHTED AND BALANCED !!
I ALSO HAVE THE GEAR BOX WHICH ALSO HAS BEEN RECONED WITH SLIP DIFF,, NEED CLUTCH THO
MY NUMBER IS 07411589172 TONY
THE ENGINE A BOX WAS FOR MY RS S1 ON A D ,!! WHICH HAS BEEN RESTORED JUST NEEDS PAINTING
all on ebay
Item number: 160818271568
will pu photos up later ..
£ 1000 the lot,,
also i have a restored shell which just needs painting, i can paint it but it will reflect on the price , ,,all running gear which has been shot blasted and stove enameled l in blue,, new poly bush kit ,, full stainless exhaust
i bought this as a runner and was tax and tested no time to finish it ,i have all parts now up for sale would sooner sell job lot £ 2000.. i have all docs and mots ,, the shell is 1997 d reg,, in white,,
anything you just send me pm !! it will be going on eBay some time this month fanx
£ 1000 the lot,, 300 for gearbox
i have spent around £ 1500 just o engine alone and have most of the parts are from burton still boxed up
Old Aug 5, 2012 | 08:28 AM
Topcat's Avatar
Topcat
Default s1 engine and gearbox going cheap,,
all on ebay
£ 1000 the lot,, 270 for gearbox
i have spent around £ 1500 just o engine alone and have most of the parts are from burton still boxed up[/QUOTE]
Old Aug 5, 2012 | 12:22 PM
simonmcf's Avatar
simonmcf
Would ya sell Kent or suspension parts separate ?
Old Aug 9, 2012 | 04:12 PM
Topcat's Avatar
Topcat
will not split engine but will sell suspension parts as a joblot with poly bush kit
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
