Overspray removal - HELP!
Old Jun 9, 2012 | 10:01 AM
Cragrat's Avatar
Cragrat
sit boo boo sit
Default Overspray removal - HELP!
Parked my van up at a job this week which was quite a distance from where i was working,came back to it a few hours later and the rear and side is covered in silver over-spray (paint,plastic & glass)!!!,perpetrator was nowhere to be seen
what is the best way to remove said `addition`
vehicle is a blue transit sportvan with a little bit of sign writing
thanks for your time
Old Jun 9, 2012 | 10:03 AM
JamesH's Avatar
JamesH
I was always told t cut?
Old Jun 9, 2012 | 10:12 AM
Cragrat's Avatar
Cragrat
sit boo boo sit
me too,but thought it may be a bit severe,thought there may be something else available
Old Jun 9, 2012 | 10:23 AM
Retro Al's Avatar
Retro Al
RWD IS KING
Try claying it
Old Jun 9, 2012 | 10:34 AM
Rsmat's Avatar
Rsmat
As above clay if not to severe.. I once used nitro morse watered down and wiped off .
Old Jun 9, 2012 | 11:11 AM
STeve's Avatar
Super Moderator
t.cut if minor and poss clay bar with loads of lube
Old Jun 9, 2012 | 11:12 AM
opposite lock's Avatar
opposite lock
Claybar might do it but i reckon you,ll struggle with it. Do you have any glue and tar removers? Failing this i would use a light to meduim cut polish or a paint cleanser type product such as Werkstat Prime Strong. You can use this on glass aswell.
T-cut will do it i,m sure as it has abbrassives that should tackle it.
Machine light cut polish is probably the best way and finish.
Old Jun 9, 2012 | 12:06 PM
polly_x's Avatar
polly_x
I would wipe it over with either thinners and then clean and polish.
Old Jun 9, 2012 | 01:06 PM
dakar's Avatar
dakar
i thought thinners would be a bit risky????
Old Jun 9, 2012 | 01:41 PM
opposite lock
Tar and glue remover is fine on cured paints , when using it neat i leave it to dwell for 30-50 seconds then wipe and see how its doing. If it eats into the overspray enough wash down with warm water afterwards to clear of any solvent.
Old Jun 9, 2012 | 01:58 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Tar and glue wont touch it imo
Old Jun 9, 2012 | 02:23 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
Soft mophead and G10
As for plastics, use thinners, but dont go mental, dealt with this many a time.
Old Jun 9, 2012 | 03:25 PM
Mats1985's Avatar
Mats1985
For windows use wire wool or a blade for paint wrk use a polish wiv a cutting compound
Old Jun 9, 2012 | 05:47 PM
coswurv's Avatar
coswurv
nitro morse?, are you sure matt that stuff is lethal
Old Jun 10, 2012 | 07:20 AM
connect sportvan's Avatar
connect sportvan
the first thing you need to work out is what is the paint?
i had a job a few months ago.where a company sprayed a running track and covered some cars in the car park with orange overspray.
clay didnt touch it.machine polishing didnt really work.
i found the best way was to wash the car first with standard thinners (cheacked for smart repairs before hand) then machine polish with a medium cut compound.
but each paint overspray is different
Old Jun 10, 2012 | 07:34 AM
graham c's Avatar
graham c
G10 should be fine so will t cut but you'd be rubbing like fook
Old Jun 10, 2012 | 08:54 AM
Cragrat's Avatar
Cragrat
sit boo boo sit
Cheers fellas
Re the paint,I think it was hammerite as there was a empty tin left nearby
Realy bloody annoying as van is now covered in feckin thousands of little silver spots....
Think I'll try the t-cut first purely as I have some already
Old Jun 10, 2012 | 09:11 AM
langer's Avatar
langer
Thinners will take it off no problem.
Old Jun 10, 2012 | 09:15 AM
slammedorion's Avatar
slammedorion
Thinners, clay, polish.
Or some panel wipe.
Old Jun 10, 2012 | 09:20 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
thinners would be the first port of call, rinse it off, dry and polish afterwards.
had this more than once in a rush to get something done then looked over and overspray on car
Old Jun 10, 2012 | 09:27 AM
Fraggle...'s Avatar
Fraggle...
On a tangent
Simply use some petrol and a rag.
Wash it after, and then a nice polish, job done
Old Jun 10, 2012 | 09:55 AM
aimee'sdad's Avatar
aimee'sdad
Would stay clear of nitro morse mate. If the paint work is good and not fresh and free of smart repairs you could wipe over with a damp thinners rag doing small areas at a time then finish off with a good polish. If you have access to a mop use a fine cutting compound and again finish off with a polish
boeb
Jan 9, 2020 05:11 AM
Orion_Gav
Sep 29, 2015 04:50 PM
