Master cylinder question
Old Jun 7, 2012 | 10:14 AM
c123s1turbo's Avatar
c123s1turbo
Default Master cylinder question
How much fluid should come out with a brake line disconnected from the cylinder and someone pushing the pedal?
Is it just a dribble? I know it doesn't take that much with hydraulics. It's just Iv got a new master cylinder and tried the above last night and not alot came out.
Old Jun 7, 2012 | 10:18 AM
martysmartie's Avatar
martysmartie
Normally it's quite alot, have you removed the top off the master cylinder, what are you trying to achieve?
Martin
Old Jun 7, 2012 | 11:09 AM
c123s1turbo
Basically I have no brakes. So I wanted to check that the master cylinder wasnt airlocked. I'm going to try an easy bleeder later if that don't work il try another cylinder
Old Jun 7, 2012 | 01:48 PM
martysmartie
Do you have pressure in the pedal?
Martin
Nov 1, 2015 06:53 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
muzzman1
Sep 30, 2015 08:59 PM
