MK5 Pedal Conversion
Old Jun 5, 2012 | 10:41 PM
lewis.philcox's Avatar
lewis.philcox
Default MK5 Pedal Conversion
Going to be doing the mk5 pedal conversion so far I have a mk5 pedal and the alloy quadrant is that all I need? I can use all the other mk4 bits or is there anything else I need to buy?
Thanks
Lewis
Old Jun 5, 2012 | 11:18 PM
Chopshop85's Avatar
Chopshop85
Just need to keep the spring thats already on the clutch in the car. oh, and I think chop that bracket off, was ages ago I did mine. There is a good thread on here somewhere with pictures etc but I can't seem to find it?!?
Also, brace yourself for what was one of the worst jobs I have ever done on an RST
Old Jun 6, 2012 | 06:18 AM
lewis.philcox
Thanks for the reply, so the bit that holds the quadrant in in place on the pedal if used off the mk4 And what not?
I will get a nice new clutch cable to I guess
Lewis
Old Jun 7, 2012 | 02:02 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Lewis
Pedal will have loads of play if the spring is not fitted...
Like this mate...
Old Jun 7, 2012 | 09:44 PM
nigel b's Avatar
nigel b
nice pics
Old Jun 8, 2012 | 08:49 PM
Hansenturbo's Avatar
Hansenturbo
nice info anyone got a part nr on the mk5 pedal?
Old Jun 8, 2012 | 09:27 PM
corkers's Avatar
corkers
iv done this the bracket def needs cutting off first ........ all i need to do is get car back on rd to test pedal feels good tho when sat in the garage making brrrummm noises pretendin to drive
Old Oct 1, 2012 | 05:45 PM
Edwin van Asselt's Avatar
Edwin van Asselt
Hello, can any of you let me know what the advantage is of this conversion?
Old Oct 1, 2012 | 06:38 PM
Chopshop85's Avatar
Chopshop85
When using an ap or helix uprated clutch the std plastic self adjusting quadrant will often crack/snap. So the alloy quadrant wont break and the mk5 pedal has the adjuster bolt.
Old Oct 1, 2012 | 08:37 PM
Roscopeco's Avatar
Roscopeco
P8 Managed S1 with ALS
What he said
Old Oct 2, 2012 | 06:48 PM
Edwin van Asselt
Thanks for your reactions
Old Oct 11, 2012 | 04:59 AM
rs shawn's Avatar
rs shawn
S1 Database Editor
If you had bought the mk5 plastic quadrant then yes, it needs modifying.
http://www.apracing.com/Info.aspx?In...0&ProductID=34
He's got the alloy version which is a straight fit without the extra work
http://extremesportsproducts.com/ind...d&productId=17
^This link also has a PDF fitting guide: http://extremesportsproducts.com/Gal...structions.pdf
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
