Modified Mongoose Exhaust - Last piece of the RS to go
Mongoose Exhaust - 3 inch bore with a 4 inch rolled out tail pipe. In very good condition, comes with clamps, new power flex mounts etc. Modified with a flexi joint, DEI heat wrap and V band fitted Cosworth downpipe. There are also 2 lambda bosses fitted for mapping.
See link below to hear the exhaust
Ideal for a big power RS Turbo.
As per all my other items, bank transfer or cash only please. I will take PayPal but only as a "gift" payment and buyer covers all fees. I could break the exhaust down and courier it out at extra cost but I would prefer this to be collected.
I'm looking for £250 but will take a decent offer just to get rid
No it won't, not unless you have a V Band fitting on your turbo housing. Adapters are around £50 from ATP in America. It is worth doing as it makes exhaust removal a piece of piss.
http://www.atpturbo.com/mm5/merchant...Category_Code=
Exact adapter will vary though. It would probably be best to speak to Vince at CR Turbos about what you need for your turbo.
Or you could somehow weld this on to the back of your exhaust housing;
