St170 tapping noise
Old Jun 4, 2012 | 03:54 PM
ricky_2006's Avatar
ricky_2006
Default St170 tapping noise
Hi,
Only just started doing it.
Sounds like its possibly coming from cambelt sort of area. So hard to tell.
When car is started it starts basically making a tapping noise. When car is warm it stops.
Could this be tappets or injectors.
Please help
Old Jun 10, 2012 | 06:04 PM
minder's Avatar
minder
Originally Posted by ricky_2006
Hi,
Please help
hi mate
mine was the same its a common fault with them when the engine is warm it went after a few mins
Old Jun 10, 2012 | 06:34 PM
mechanicalrepairs's Avatar
mechanicalrepairs
Seen a few of the timing belt plastic pulleys crack causing noises like this, recommend removing the timing belt cover to take a look, better safe than sorry.
carl
Old Jun 10, 2012 | 08:34 PM
Sp3no's Avatar
Sp3no
They have solid l
lifters so its normal for them to be noisey on start up specially when the shims start to wear
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
gingeRS
17
Oct 2, 2015 09:42 AM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
