Starter ticking
Jun 4, 2012 | 12:49 PM
Starter ticking
Went to start the car after its not run for a few months fully charged the battery and nothing happens it just ticks?
Any ideas
Jun 4, 2012 | 12:54 PM
Give the starter motor a little tap, might be stuck. Had to do that with my pug 205.
Jun 4, 2012 | 12:56 PM
Jun 4, 2012 | 01:00 PM
We recently had a problem with a van at work after disconnecting the battery, turned out it was a loose wire under the battery.
Jun 4, 2012 | 01:03 PM
Theres a thin blue wire that can snap/corrode check this. Check all other connections and earth point.
Also give it a tap as suggested if its been stood.
Jun 4, 2012 | 02:27 PM
Or put the car in gear and rock it back and forth then try it.
Jun 4, 2012 | 07:01 PM
The wire at the bottom has frayed got it going in the end but will replace the wire!
A.t.p
Oct 23, 2015 07:54 PM
cossie362
Oct 11, 2015 03:53 PM
Fiddy
21
Sep 29, 2015 06:10 PM
marky_g
Sep 12, 2015 04:26 PM
dojj
Sep 8, 2015 08:31 AM
