wiring
Old Jun 3, 2012 | 09:09 PM
Lee1707's Avatar
Lee1707
Default wiring
After a few days removing old alarm syatems, 3 in total due to blowing fuses etc i have now come across what i beleive to be my last stumbling block prior to starting the car again. Ignition switch to complete.
I went to ford to see if i could order Ignition switch PN V92AB 11572 AA. I believe this has 2 connectors on it, 1 x 4 Pin rectangular connector to the Fuse box, Fuse box connection 4 wires, 1 x red, 1 x black, 1 x yellow & 1 x black with blue strip.
Larger 4 pin connector is for what i think is part of the Pats system. 2 x yellow & 2 x black wires. the other end of the connector ties into the harness next to central locking module drivers footwell
Guess what same old story, no longer available!
When the Clifford Alarm was fitted previously all the original wiring from the ignition Switch was removed and replaced with black cabling.
Could anybody provide a photo or schematic of the above harness to help with me making up a new harness?
Lee
Old Jun 4, 2012 | 10:47 AM
tones's Avatar
tones
Hi, i have pm u my phone number as i have just had a brand new wiring harness fitted to my car. I might be able to help you out.
Lee
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
cossie brad
Sep 29, 2015 02:38 PM
IainRS1700T
Sep 25, 2015 06:44 AM
