garage clear out
having a clear out, prices are to clear. no offers
prices are plus delivery
4x4 thermostat housing
£15
4x4 throttle body, where the iscv sits their is a little bit missing but car was fine with it bolted up
£20
2x 2wd distributor caps, used but good condition and 1 rotor arm
£3.50 each
ignition amp bracket
£5
2wd ecu bracket
£7.50
3 door interior b pillar trims
£7.50
custom 'twins' gauge holder, no gauges included
£20
also have a 4x4 front and rear prop
£10 each
thanks for looking
£15
£20
£3.50 each
£5
2wd ecu bracket
£7.50
£7.50
£20
£10 each
thanks for looking
Hello mate
I know you said no offers but it you want rid of the throttle body il give you £10 for it for spares as I could do with the spindle and a bearing from it
No worries if that's not enough, just thought I'd ask
Thanks
Marc
Thanks
Marc
rsguy
44
Sep 29, 2015 03:29 PM
