what to do with the S2
Old Jun 1, 2012 | 06:32 PM
corkers's Avatar
corkers
Default what to do with the S2
hi im currently doing a light resto to my s2 and am wanting a bit of advise what to do next really ..... im not looking for big power just a good fun car here is what iv done to date......
Serviced it
Airtech rad
msd fan switch
new gaskets
looking at ordering an airtech intercooler
heat wrapped exhaust and manifold
had gearbox rebuilt
new clutch
steel quadrant and mk5 pedal
body wise rust is ok hasnt long had front wings and spray job
i have waxoiled arch's
undersealed underneath the car
im looking at getting an actuator but not sure which one to go for
and getting it chipped
any guidance or advice would be great
cheers
Old Jun 1, 2012 | 06:51 PM
Ryoishikawa's Avatar
Ryoishikawa
I've got standard engine with
Msd fan switch
Msd thermostat
Aic tec front intercooler
Air tec rad
-31 actultor
Power engineering chip
Piper cross panel filter
I'm getting 161.9bhp and 194 toque I think that's enough for road use
Old Jun 1, 2012 | 06:56 PM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
If you are getting it chipped you will need a -31 preferably a genuine garrett or a collins and chipping it you are best going for an ahmed bayjoo, turbosystems (if you can get hold of one 2nd hand) or maybe a collins chip 2nd hand ecu's regularly come up on the ford forum's and ebay at a fraction of what they are new you will also benefit from a full 2.5 inch bore stainless exhaust and a k&n or pipercross panel filter and then get the car set up by a pro
Old Jun 1, 2012 | 06:57 PM
corkers's Avatar
corkers
i think i would be happy with that what actuator is that and where best place get hold them i have looked on burton and msd but not sure which one to go for
Old Jun 1, 2012 | 07:02 PM
milesy23rst
PUG 306 GTI-6
Garrett -31 actuator are around a Ł100, collins -31 are around Ł70 i think i would personally use msd or collins for the actuator m8
Old Jun 1, 2012 | 07:06 PM
corkers's Avatar
corkers
seen this on msd is this what im after?
http://shop.motorsport-developments....ator-222-p.asp
Old Jun 1, 2012 | 07:11 PM
milesy23rst
PUG 306 GTI-6
Its not a genuine one m8 i think dave (twins) has a genuine one for sale in the rs turbo section and its either new or nearly new have a look at his for sale thread, just had a look m8 its a genuine garrett he is selling for Ł75 posted and it was only on the car a week!!
Old Jun 5, 2012 | 05:20 PM
corkers's Avatar
corkers
thanks for your help
Old Jun 5, 2012 | 06:44 PM
milesy23rst
PUG 306 GTI-6
No worries did you buy the genuine one of dave (twins) ??
Old Jun 8, 2012 | 09:14 PM
corkers's Avatar
corkers
no he had already sold it as only contacted him on the tues as was away all bank hol so still on a look out for one
Old Jun 10, 2012 | 11:47 AM
xtatiana01x's Avatar
xtatiana01x
Buy a unlimited boost chip on eBay from the above company's second hand
Then buy a brand new actuator ONLY
And most important mod on a rst is a breather kit
Old Jun 10, 2012 | 03:40 PM
studabear's Avatar
studabear
May I suggest a brake upgrade, cosworth 4x4 front calipers and sierra cosworth 2wd 283mm discs.
Old Jun 10, 2012 | 04:36 PM
E980VTJ's Avatar
E980VTJ
how important is a breather kit,mines still standard
Old Jun 10, 2012 | 05:34 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Going aftermarket is not important... However, making sure whatever breather setup you have is clean and clear is important.
Old Jun 11, 2012 | 04:04 PM
corkers's Avatar
corkers
what is the visual difference with the sierra 4x4 calipers?
Old Jun 11, 2012 | 07:23 PM
studabear's Avatar
studabear
there bigger, take a read through this
https://passionford.com/forum/ford-e...07-2011-a.html
