is the dohc 4x4 gearbox the same as the cos 4x4?
Old May 30, 2012 | 08:22 PM
The Youth.'s Avatar
The Youth.
Default is the dohc 4x4 gearbox the same as the cos 4x4?
I blew both my gearboxes last week and need another one quick a m8 has a 2.0 dohc one and were are not sure if they are the same, there is a hunch that the clutch arm is different but as I run a hydraulic clutch I would be using my own anyway.
Anyone got any ideas?
steve
Old May 30, 2012 | 08:27 PM
M K's Avatar
M K
Clutch arm exits on the other side of the box i think
Old May 30, 2012 | 08:35 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
Bell housings are different, so startermotor is on the other side but inside all is the same as far as I know.
Old May 30, 2012 | 08:42 PM
graham c's Avatar
graham c
It fits ! But only if it is the 2.0l dohc 4x4 I've fitted one before
Old May 30, 2012 | 08:47 PM
The Youth.'s Avatar
The Youth.
will have a look tommorow, im sure the clutch arm is on the same side as a cossie one tho
steve
Old May 30, 2012 | 09:53 PM
a-mac's Avatar
a-mac
yes they are the same but as you say fit the clutch arm off cossie box
as i fitted mine with dohc clutch arm and would not press clutch right
Old May 30, 2012 | 10:42 PM
xr4x4rs's Avatar
xr4x4rs
as above fit fine just change clutch arm, infact there be better than buying a cossie box becuase they wouldnt of had the abuse or power going through so may last a bit longer
and you can pick them up cheaper
Old May 30, 2012 | 10:46 PM
TONY C's Avatar
TONY C
its not just the clutch arm, the pivot is also different, different length, just knock them out and swap
`spotty
Sep 25, 2015 11:41 PM
rog
Sep 16, 2015 03:00 PM
mike elsome
Sep 14, 2015 04:08 PM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
Adam Graham
Sep 6, 2015 06:04 AM
