Rs turbo stage 3 head and bottom end
FERRIDAY ENGINEERING CROSSHATCH STAGE 3 CNC HEAD BIG VALVE NEWMANS CAM, the head has been stripped down and the only worn parts i can see are the lifters, PIPER CAM PULLEY BLUE ONE
£300
FERRIDAY ENGINEERING 1.6 CVH ACCRALITE PISTONS 1mm over size, burton power FARDON STEEL RODS. high pressure oil pump
£500
THE ENGINE HAS DONE 5000 MILES SINCE BUILT, ONLY REMOVED BECAUSE CAR WAS STRIPPED, HEADS OFF SO CAN INSPECT.
VIEWING WELCOME, ENGINE IS ON STAND.
07779816045 CRAIG.
£300
£500
07779816045 CRAIG.
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
ekjim
Aug 17, 2015 08:57 PM
