Ford Range This section is for other models in the Ford range.
Mk4 Escort Early head on later block?
Old May 30, 2012 | 08:48 AM
simon68's Avatar
simon68
Default Mk4 Escort Early head on later block?
Can any one tell me if it's okay to put an early 81SM6090 XR2 Xr3 1600 head on a later 'Leanburn' engine? Or if there will be any adverse effects or alterations needed.
Many thanks.
Old May 31, 2012 | 10:38 PM
simon68's Avatar
simon68
most be some engine builders on here that could help
Old Jun 1, 2012 | 06:04 AM
mattxr3i's Avatar
mattxr3i
I have put a hemi head on a lean burn bottom end before and ran it for a year. Went quite well actually as it is supposed to lower the compression ratio
Old Jun 1, 2012 | 12:17 PM
simon68's Avatar
simon68
thanks for that matt.So i'd lose a few hp's?
Old Oct 28, 2012 | 06:44 PM
B3rtie's Avatar
B3rtie
It might though the head could be skimmed down (or use early pistons?) to raise the compression ratio again.
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
saul1988
Wheels and Tyres
Aug 24, 2015 06:42 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
