MOT Help.....
Old May 29, 2012 | 06:45 PM
KW-rscos's Avatar
KW-rscos
Default MOT Help.....
Got my MOT coming up and have put RS2000 Recaros into my R reg Escort GTi, but because there are no multi-plugs on the recaros for the airbag system, the airbag light is constantly flashing, so my question is, with the new regulations will it fail on this and if so, what can I do to trick the system to thinking its all fine and dandy??
Old May 29, 2012 | 07:05 PM
GVK.'s Avatar
GVK.
Airbags aren't part of the test just yet, it's being introduced later in the year.
You can add resistors in the pre-tensioner wiring to 'fool' the light if you want..
Old May 29, 2012 | 07:09 PM
RS2000CUSTOM's Avatar
RS2000CUSTOM
At the moment at worst you will only get an advisory for a non-functioning or faulty SRS/Airbag light
We have been instructed that the "new fail" items will become live "in the summer"
VOSA though have not stated which summer and at what part of the summer the new testable items will be introduced !
Old May 29, 2012 | 07:30 PM
KW-rscos's Avatar
KW-rscos
Excellent, thanks guys, any idea what ohm resistor?
Old May 29, 2012 | 07:38 PM
GVK.'s Avatar
GVK.
Same value as the resistance of your pre-tensioner.
tip- DON'T measure this with an ohm meter.
Theory is that the ohm meter puts voltage down the wire to measure the resistance of the component (gets it's power from it's internal 9v battery), which may be enough to be able to set off the air-bag/pre-tensioner.
MATT222's Avatar
MATT222
can't you take the pretenioners off your old seat's and bolt them on the new ones? as there only seat belt stalks?
Old May 29, 2012 | 09:48 PM
stevieturbo's Avatar
stevieturbo
C**t
Dont they come live from April/May ?
The additional rules came into force here on May 1st. Even the totally and utterly silly ones.
Old May 30, 2012 | 06:37 AM
tarry500's Avatar
tarry500
Why do they not have them? mine do.
Old May 30, 2012 | 09:56 AM
KW-rscos's Avatar
KW-rscos
Unfortunately I got rid of the old seats when I put the recaros in and they are from an earlier car so they dont have the multiplug for the tensioner.... will try the resistors instead.
Old May 30, 2012 | 07:04 PM
studabear's Avatar
studabear
remove air bag fuse, its only gonna be a fail if the airbag light indicates a fault, if it doesn't light up it doesn't fail. Which to be honest is bloody stupid, but thats the way its gonna be.
Old May 30, 2012 | 08:40 PM
daz1968's Avatar
daz1968
I thought it was just an advisory to be issued this year then proper enforcement next year. I have hid lights but no auto levelling or headlamp washers on my jdm sti, as per factory spec got mot on saturday so will see how it goes.
Old May 30, 2012 | 08:46 PM
steve4i's Avatar
steve4i
They technically came into force on jan1st 2012 as a 3month probation period pass and advise for the new testable items untill april the 1st when it was going too all go live but they sent round a special notice saying they are extending the probation order due too some problem with tow bar electric test's and state too carry on advising on the new testable items untill further notice but they dont know when the new testable items will come into affect
Old May 30, 2012 | 09:11 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
But if the light doesn't come on then go off when you turn the ignition on, and you physically have no pre-tensioners, it will fail.
Old May 30, 2012 | 09:42 PM
studabear's Avatar
studabear
if it doesn't light up its pass and advise.
Only thing testable re pre tensioners is if the flag is showing, not the presence.
It was in matters of testing, I will see if I can find it at work and scan it. Also check I've 100% interpretated it correctly
Old May 30, 2012 | 09:45 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
why do northern ireland need different mot rules? youre part of the same country. Youre drivers cant be that much more retarded to need higher mot standards
Old May 30, 2012 | 10:05 PM
studabear's Avatar
studabear
warren, carefull D-sport doesn't see this or fuzzy
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Nick 172 Sport
Sep 28, 2015 07:21 PM
