i want to calculate compression ratio before built my engine
Old May 29, 2012 | 04:18 PM
sierrafun's Avatar
sierrafun
Default i want to calculate compression ratio before built my engine
hello folks . i want to built my engine ...i have head 4x4 138.4mm 90.83 standar bore satandar stroke .i want to fit wrc gasket 0.50 and pistons 8.1 cr what cr i will have finally .somebody can help ? because i dont know the type to give the cr
Old May 29, 2012 | 04:48 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
You need to know:
Bore
Stroke
Volume above piston
Deck height
Gasket volume
Cylinder head volume
anything else will just be a guess
Sounds like you are missing head volume, piston volume, and deck height
WRC gasket volume someone on here will no doubt know though
Old May 29, 2012 | 04:52 PM
sierrafun's Avatar
sierrafun
Originally Posted by Chip
You need to know:
Bore
Stroke
Volume above piston
Deck height
Gasket volume
what about 138.4 and 0.50 wrc gasket ..about how much cr ? it will be higher ?8.5 or 8.3 ?
Old May 29, 2012 | 04:58 PM
sierrafun's Avatar
sierrafun
i want to go for higher cr . i have stronger sleeves ..with 8.1 cr pistons and 0.50 gasket wrc ..you know if i go for higher cr
1300gt
Sep 7, 2015 12:06 PM
YODI
Aug 30, 2015 01:12 PM
155lee
Aug 14, 2015 11:21 AM
taylora1409
Aug 12, 2015 12:06 PM
Zoggon
Aug 10, 2015 10:39 AM
