filler cap,if taken off it cuts out?is this good or bad?????
Old Mar 1, 2005 | 09:19 PM
cossie_wona_b's Avatar
cossie_wona_b
Default filler cap,if taken off it cuts out?is this good or bad?????
can some tell me y people check filler cap....i mean take it off whilst engine is running??
ive looked at 1 2nite and it cut out when i took cap off ....wot does this mean?????????
Old Mar 1, 2005 | 09:35 PM
adamS2RST's Avatar
adamS2RST
Why the fook you taking the the petrol cap off?
I assume you mean oil filler I honestly cant remeber if it should or shouldnt cut out when removed, I think it could mean the breathers blocked.
Old Mar 1, 2005 | 09:38 PM
cossie_wona_b
yes i do mean filler cap dude
Old Mar 1, 2005 | 09:40 PM
cossie_wona_b
oil filler cap!!!
Old Mar 1, 2005 | 10:35 PM
AKRS1's Avatar
AKRS1
it shouldnt cut out. Ive driven mine with the cap off without knowing it only to smell oil through the vents
Old Mar 1, 2005 | 10:40 PM
220TC's Avatar
220TC
I believe it should cut out due to when you remove the filler cap there is a massive air leak. If you have an aftermarket breather system that vents to atmo then it wont cut out..........at least thats what mine does
Old Mar 1, 2005 | 10:42 PM
DazC's Avatar
DazC
If the standard breathers are working correctly it SHOULD cut out. If they are blocked then it won't cut out or will run lumpy. The reason is the fuel metering unit draws on the breathers and it meters this air. When you take the cap of, you introduce unmetered air into the induction system which also drops the amount of vacuum and causes it to run too lean for it to stay running.
A poorl sealed dipstick or gaskets on the engine can also effect the way the engine runs.
My car has had the breathers removed from the induction system completely and have blocked the port of in the the meter unit and the car set up accordingly. The breathers than go to a breather oil seperator and then to atmoshpere (a catch tank could also be used but it still ultimately breathes to atmosphere).
Old Mar 1, 2005 | 10:47 PM
220TC's Avatar
220TC
thats what I meant mate .........well put
Old Mar 1, 2005 | 10:55 PM
GrimmeRS2K's Avatar
GrimmeRS2K
before i rebuilt my engine, my car had covered 140k and would run with the cap off, since the rebuild it cuts out.
Old Mar 2, 2005 | 06:23 AM
adamS2RST's Avatar
adamS2RST
Well Done Daz
Old Mar 2, 2005 | 08:40 AM
Stu @ M Developments's Avatar
PassionFords Creator
Perfect explanation.
Old Mar 2, 2005 | 05:50 PM
rsnitrouskev's Avatar
rsnitrouskev
as 220 tc said it will cut out or it should unless u got a baileys oil breather on there then it should still run
markk
Dec 2, 2021 06:59 PM
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
Mark RS
14
Aug 11, 2015 11:45 AM
mattman1234
24
Aug 1, 2015 11:46 AM
