Gripper diff oil questions
Old May 28, 2012 | 10:22 AM
M K's Avatar
M K
Default Gripper diff oil questions
What oil should I use in my gripper rear diff? And also does anyone know the optimum oil temp so I can work out what temp switch I need to control the rear diff cooler
Was looking at 87degrees c to turn cooler pump on and 72 degrees c to turn pump off
Thanks
Marc
Old May 28, 2012 | 11:24 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Old May 28, 2012 | 05:51 PM
105epwr's Avatar
105epwr
I use the Morris 80w/140 direct from gripper as they have tested loads of different makes/viscosity and found this stuff to be the best.
They also stock it
Old May 28, 2012 | 06:34 PM
M K's Avatar
M K
Thanks guys
What about oil temps for the diff cooler set up?
Maybe I should email gripper
Old May 28, 2012 | 08:05 PM
105epwr's Avatar
105epwr
I'd ring them to get a solid answer tbh.
There very helpful
Old May 28, 2012 | 08:43 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
80/140 in mine as well
Steve
Old May 29, 2012 | 01:41 AM
BRAMMER's Avatar
BRAMMER
Slightly off topic but where have folk found the cheapest supplier of 7.5" gripper?
Old May 29, 2012 | 03:30 AM
Gav Diamond's Avatar
Gav Diamond
Got mine direct from Tom Seal when he was at Coventry Automotive (I think it was) but believe he has moved since.
Old May 29, 2012 | 06:28 AM
ajamesc's Avatar
ajamesc
I got mine from gripper in coventry for 700 pounds
Old May 29, 2012 | 07:27 AM
DAN-Saff's Avatar
DAN-Saff
Tom seal works out of Dave mac prop shafts now.
Old May 30, 2012 | 06:30 AM
BRAMMER's Avatar
BRAMMER
Now priced at £770 + vat and post
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
Fezman1
Sep 7, 2015 09:34 PM
cbminis
Sep 7, 2015 09:42 AM
