Bonnet catch
Old May 28, 2012 | 06:34 AM
lewis.philcox's Avatar
lewis.philcox
Default Bonnet catch
My bonnet catch is catching on my intercooler slighty now I've Bent the catch up but how safe is that?
Is there a check strap I can put in or something?
Or is it time for bonnet pins
Old May 28, 2012 | 09:33 AM
dazrsturbo's Avatar
dazrsturbo
i have the same problem. im thinking of fitting some kind of safety strap too. really dont want bonnet pins.
Old May 28, 2012 | 09:42 AM
rs combi's Avatar
rs combi
Speak to Jano he sells them
Old May 28, 2012 | 10:32 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
use a mk3 escort catch or cut the mk4 one to the same as a mk3.
Also use a check strap that is available if you search.
Old May 28, 2012 | 10:38 AM
lewis.philcox
any pics of the catches anywhere?
il have a look for the check strap i did drop you a email today jano
Old May 29, 2012 | 06:28 PM
H7 CYA's Avatar
H7 CYA
I'm also in this predicament will look into a mk3 catch
Old May 31, 2012 | 11:23 AM
Versus_Creations
Ask me a question!
cut them its much easier than finding a good mk3 one anyways.
Ill see if i can find a pic.
Look at your bonnet catch and where it touches the bonnet, if you notice there is a inner section of the bonnet at this position, so you need to cut the end of the handle so that it will push inside the bonnet as such. Then just bend it slightly so it stays away from the rad and cooler. Then add a check strap for peace of mind.
Old Jun 1, 2012 | 10:22 AM
dazrsturbo's Avatar
dazrsturbo
i had the same prob with my bonnet latch so i cut and bent it so it would go up into the bonnet. wrks a treat. heres some pics
Shaunc
Escort Range
Sep 22, 2015 06:38 PM
Adam Graham
Sep 6, 2015 06:04 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
