Probelm with ecus CARD and COSY small turbo cosworth
Old May 26, 2012 | 09:05 PM
21turbojon's Avatar
21turbojon
Default Probelm with ecus CARD and COSY small turbo cosworth
Hi, need your help.
I have a small turbo escort cosworth with oem CARD ecu and run propertly but today i have changed CARD ecu to COSY ecu with GGR chip, and engine dont start, when turn ingition on and try start, fuel pump dont start, and engine dont start.
If I remove the chip from the COSY ECU, I attempt to restart the engine, this still does not start.
If I install the OEM ECU "CARD" the car starts and runs properly.
where can be the problem?
The COSY ecu was damaged?
I removed the covers from the ECU "COSY" and is not any component (transistors, capacitors ...) burned.
You know if the control units of all escort cosworth ECCIV can be exchanged between them?CARD vs COSY
could install the chip in my ECU card?
The chip is engraved with the following letters in the connector:
EECIV 0149
and
512L2V1
i Thik it is level 2 305BHP conversion but i am not sure.
I need your opinions.
Thanks in advance.
Regard
Old May 27, 2012 | 05:31 PM
THE RADMAN's Avatar
THE RADMAN
assuming you have the orig ford pats alarm system then this is coded to your ign key and ecu,if you change the ecu on its own then it wont work anymore
Old May 28, 2012 | 07:11 AM
21turbojon's Avatar
21turbojon
My car has the original ford alarm, but the slot is located next to the ashtray appears to be disabled. I removed the center cap which is the gearbox and there is no cable to the slot.
As could be sure that what is failing is the alarm system and if so unlock the unit to work with this unit chipped?
Regards
Old May 28, 2012 | 07:29 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
correct
Old May 28, 2012 | 12:39 PM
sailorbob's Avatar
sailorbob
The COSY ecu will not start your car because of the PATS. You can use the chip in your CARD ecu, just make sure you clean the J3 connector well and avoid damaging the circuit traces.
Old May 29, 2012 | 04:07 PM
THE RADMAN's Avatar
THE RADMAN
Regards
yes,that one may be, but you will still have the seperate pats sytem that uses the chip in your ignition key
3i Jim
Nov 20, 2015 05:12 AM
IAN RS2k
Aug 18, 2015 07:51 PM
Aug 14, 2015 07:29 AM
no1trancefan
Ford Focus ST
Aug 6, 2015 05:09 PM
no1trancefan
Aug 4, 2015 12:48 PM
