cosworth 4x4 rev counter its broke me !!!!!1
Old May 26, 2012 | 07:46 PM
dissmalrs's Avatar
dissmalrs
Angry cosworth 4x4 rev counter its broke me !!!!!1
(Fixed)
right its broke me now i need help
been looking at my rev counter looked all over this sight for an answer but still cant work it out why my rev counter wont work
this is what i have got
4x4 cosworth 1992 running wasted spark
it has a secs computer in and that has a rev counter on it as well
cant see anything wrong with the rev counter itself all looks good the rev counter on the secs computer is working fine it has had the msd mod to the back of the rev counter and the green wire under the bonnet are connected i get the same voltage there as i do under the dash about 0.5 volts at idle going up with the revs
need to know what voltage should i get at the green wire on the connecter at the clocks
and if its not working right why am i getting a reading on my secs computer
could it stop the revcounter on thedash working
help its driving me mad
cheers darryl
p.s. sorry for the essay
Old May 26, 2012 | 10:19 PM
Longshanks's Avatar
Longshanks
Have you spoke to msd?
Originally rev counter is from the coil which you no longer have . I am sure this is quite common.. Give them a call they are good and will help you..
Old May 26, 2012 | 10:23 PM
dissmalrs's Avatar
dissmalrs
yeah have spoke to them and got the info about the mod they were really good
gonna try talking to them on monday as this is driving me mad
cant understand why its working on secs computer but not on rev counter
cheers for the reply
darryl
Old May 26, 2012 | 10:34 PM
Longshanks's Avatar
Longshanks
It's these little problems that piss you off . Hopefully it will turn out to be an easy fix mate. Let us know the outcome
Old May 27, 2012 | 06:17 AM
dissmalrs's Avatar
dissmalrs
thanks i will do im just thinking about putting an after market rev counter i the thing
Old Jun 3, 2012 | 10:32 PM
tomoyb's Avatar
tomoyb
im in same boat its really annoying
Old Jun 4, 2012 | 12:37 AM
dissmalrs's Avatar
dissmalrs
i might have found a way round this little fucker ill try it out and ill let u know if it works
Old Jun 4, 2012 | 05:53 PM
costina's Avatar
costina
Live long and prosper!!
Dissconnect the suppressor from where the original coil was and join the cables together they are both green.
Paul
Old Jun 4, 2012 | 08:32 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Your secs might work upto about 3k like mine, then goes to 0
Steve
Old Jun 4, 2012 | 08:35 PM
costina's Avatar
costina
secs will never work if it does its half the actual rpm
Old Jun 5, 2012 | 12:21 AM
dissmalrs's Avatar
dissmalrs
no mine works fine all the way up as far as i can tell
Old Jun 5, 2012 | 10:22 AM
costina's Avatar
costina
Now thats really strange how have u managed to do that? whatever pin u have your secs connected to for rpm connect your tacho too and see if that works
Old Jun 5, 2012 | 11:08 AM
Karl 3dr's Avatar
Karl 3dr
I had a similar problem with mine when i first had wasted spark, mine turned out to be a problem with part of the wasted spark board, I've circled the part that was faulty, it had overheated, have a look at yours to see if the insulation has cracked on it, if it has i would speak to msd
Old Jun 5, 2012 | 07:14 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I want to know what pin he has wired the secs to.
It would be nice if it worked
Steve
Old Jun 5, 2012 | 09:15 PM
costina's Avatar
costina
Steve
me too
Try either pin 3 or 5
Old Jun 5, 2012 | 09:56 PM
martysmartie's Avatar
martysmartie
I think it depends on what 'Firmware' your SECS has?
As I know there was an update planned for the tacho to work with WS.
Martin
Old Jun 5, 2012 | 09:58 PM
dissmalrs's Avatar
dissmalrs
me too
well iv finished my P.O.T.L. now so wont have as much time to mess about but ill try trace it back asap and let u know
cheers darryl
Old Jul 17, 2013 | 12:11 PM
dissmalrs's Avatar
dissmalrs
Default rev counter broken wasted spark (fixed)
thought i would update this tread
i finally pulled my finger out and got round to sorting this as karl pointed out it was the component that had failed
spoke to msd and they sent me one for free (twice as i lost the first one )
soldered it in and bosh working
thanks for the help and to stu at msd for his fantastic customer service
Old Jul 18, 2013 | 07:38 AM
Karl 3dr's Avatar
Karl 3dr
Cool, glad you got it sorted mate
Karl
Anutternutter
Aug 21, 2015 06:07 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
ekjim
Aug 17, 2015 08:57 PM
cozzy jeff
Aug 14, 2015 05:46 PM
stevierob
Aug 11, 2015 09:08 PM
