anti roll bush 24mm nut problem
May 25, 2012 | 09:33 AM
Hello I'm haveing a bit of trouble with the 24mm nut it won't undo I've put wd40 on it plusgas air gun impact wrench not happening any ideas ?
May 25, 2012 | 12:16 PM
left handed thread???????
May 25, 2012 | 12:27 PM
I'm sure it's a conventional thread, it's only the hub nuts that are left handed thread.
You have to consider the time that has been there without being touched, it may need heat applying to it.
Martin
May 25, 2012 | 12:44 PM
Haven't got oxelin bottles
one did undo a little on the passenger side but no more
May 25, 2012 | 02:30 PM
i had this problem, just got a dremel with a cutting disc on and sliced carefully through it so as not to cut into the thread, then they just came off
cheers Matthew
May 25, 2012 | 02:46 PM
Was going to use a grinder lol
May 25, 2012 | 03:27 PM
gas axe to warm it up or use a nut splitter
May 25, 2012 | 03:40 PM
Where would I get them halfords ? N how much m8 ?
rex647
Mar 6, 2022 06:20 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
