what would this indacate
loads of white spoke pumping out, engine temps really high even with stage 2 airtec on, , what is the cure for the old girl its a cvh 1600
So if the was cracked is that the reason for skimming could you tell by looking at the head if it was cracked or would it need to be xrayed or sum thing ? Once taken off of course
Sometimes you can see the crack and sometimes not but on the cvh its normally between the valves
cheers danny
way to tell is crack test or pressure test. tbh its probably just the head gasket. get a light skim as a matter of course. use a genuine (payern) gasket. so long as you havent continued to drive/thrash it with the h/g blown you should be ok without further damage. driving it while the h/gasket is knackered will lead to big problems. big temps mean big trouble. get it fixed, its piss easy d.i.y and not that expensive if getting a mechanic on it.
Sounds very headgasket like to me. Whip the head off and have it crack tested and skimmed (only if needed), new genuine Ford or Payern headgasket and new stretch bolts for the head. DIY the whole lot and it should be cheap as chips
when you say white smoke, you sure it's not oil in the exhaust from the turbo seals leaking, pop the exhaust off and check for oil in the pipe.
does sound like a head gasket failure though.
if your getting high temps its going to be headgasket, worse case head is cracked
the white smoke your seeing is steam, so if the head gasket is split or the head is cracked its allowing water into the cylinders which is being pushed out into the exhaust causing the steam, but if you let it get that hot becuase the head is alloy it warps the head and you can only take so much off before the head is scrap anyhow.
dont run it up anymore, get the head off or take it to a garage to be sorted, becuase water doesnt compress so your causing more damage by keeping it running
another thing to check is your dipstick and oil cap, check to see if you have any white sludge in there or on dipstick, becuase this will show water in your oil which isnt good either becuase the water will get into your engine and then cause a lot more issues
the cheapest if just a headgasket in what you need is
headgasket and top end gasket set
headbolts
cambelt
may asel put a tensioner on aswell
spark plugs
oil and filter
may aswell do thermostat aswell while its all off
head skim and pressure check
if head is scrap then new head, you can use your cam and lifters from your head anyhow, or replace with a higher lift cam while its off
headbolts
cambelt
spark plugs
oil and filter
If it's not loosing any coolant, then it's not a HG!
Martin
steven mc kay
96
Apr 12, 2009 06:17 PM
