Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Focus aircon/heater problem
Old May 23, 2012 | 06:04 PM
Focusstew's Avatar
Focusstew
Angry Focus aircon/heater problem
Help! Have recently changed the heater fan in focus 1.6 Zetec - 02 reg as it had stopped working. Wouldn't work on anything other than setting 4 on the switch. The old fan was very stiff. Bought 2nd hand and a new resistor. Now the fan still won't work on setting 1 on the switch only 2 to 4. However, the aircon light comes on at switch setting 1 but none of the others. Not helpful when the fan doesn't work on #1.
Any advice welcom
Stew
Old May 23, 2012 | 08:16 PM
martysmartie's Avatar
martysmartie
A faulty resistor pack will stop it working anything other than position 4!
I suspect you have a faulty switch causing your problem now!
Martin
Old Aug 6, 2014 | 11:12 AM
Focusstew's Avatar
Focusstew
Okay, this fault has been ongoing now for about two years. I have changed the resistor, switches and the blower motor. I have no blower on switch setting 1, but the other three are ok. I have no air con, but the indicator light comes on, when the blower switch is on 1 (no air tho'). the indicator light goes out as soon as the switch is set to 2. Please help!!!
Old Jun 28, 2016 | 10:02 AM
Johnhorsley5's Avatar
Johnhorsley5
Default Same symptomn
I have the same symptoms. Any solution?
Old Jul 1, 2016 | 07:39 PM
Johnhorsley5
I had the same problem in that the fan would not work on setting 1. I replaced the blower resistor pack and it fixed it. I can't work out why, but it fixed it. I also found that by dropping one of the pieces of trim I could use a long screwdriver
Old Nov 7, 2016 | 07:41 PM
FordJonah's Avatar
FordJonah
My aircon comes on as soon as I move the dials for the blowers but I am getting 3 and 4
Any suggestions on the best course of action?
Old Nov 8, 2016 | 08:31 AM
Is you heater nobs turned towards the windscreen?
Old Nov 9, 2016 | 09:18 PM
FordJonah's Avatar
FordJonah
Also finding that the car is warming up okay but occasionally the gauge drops when the heaters are on full
Only had a thermostat in last year as well. Just my luck
Old Nov 12, 2016 | 07:28 PM
FordJonah's Avatar
FordJonah
Heater blower resistor replaced
Everything sorted
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
jaysoc1
Aug 20, 2015 08:18 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
taylora1409
Aug 12, 2015 12:06 PM
